#339445 - 13/11/2010 16:47 "No hard disk found -- contact support" doesn't turn off with ignition
Description: When the hard disk in the empeg is not found, the sad tux is displayed with the message "no hard disk found, contact support". If I turn of the ignition, the empeg remains powered on in this state.
Expected result: Upon turning off the ignition, the empeg should turn off immediately. It cannot honour the timeout setting in config.ini, since it's on a (now dead) disk.
Actual result: the empeg remains powered on at the error screen.
frown and wink
#339452 - 14/11/2010 02:11 Re: "No hard disk found -- contact support" doesn't turn off with ignition [Re: Roger]
uh...isn't reporting bugs an exercise in futility at this point?
#339457 - 14/11/2010 12:45 Re: "No hard disk found -- contact support" doesn't turn off with ignition [Re: JBjorgen]
Not entirely. wink
If something like that happens more than just once, I could be motivated to work around it in Hijack.
All of my notebooks have the full empeg/hijack development environment on them, even to this day.
